Hi
First sail of the season and won the shake down persuit race....good stuff.
I have fitted a new mast ball on the front beam over the winter as the original 21 year old was badly worn on the front and top. On putting the boat away I noticed a bit of grating on moving the mast round and am thinking the rivets holding the new mast heel plate added last season are catching on the raised steel pin sticking out of the top of the ball. This didn't happen on the old one as the pin was worn away. I can also move the mast on the ball a couple of ml forward and back.
I have ordered a new heel plate and wonder if I should stick it into position using something like chemical metal (or anything else suggested), so there is nothing to grate on.
Is a small bit of movement on the plate normal when a new mast ball is fitted.
Any feedback welcome
Kevin
Sprint 15 1615
