Rear Mast Support for towing
chris prior
Post by chris prior »
Hi all,
My previous Sprint had a pintle mast support which was great for towing. Having now changed to a newer Sprint I find that I have nothing to put the mast on except the rear crossbeam with some padding added to protect both.
Any sensble suggestions for towing security or the availablity of some suitable support would be appreciated. :D
Chris
Re: Rear Mast Support for towing
Hi Chris,
Presumably you changed the trailer when you changed boats and the new trailer does not have the type of trailer board that incorporates the mast support and the trailer board and lights into a pintel mounted assembly. These are by far the best in my view so if I was you I would either buy such an assembly which mounts on the pintels (they come up from time to time on Ebay) or to make one. It would be quite easy to make one out of a plank of wood and a couple of pintels. It only needs to be a mast support if you have a number plate and lights elsewhere on the trailer.
Windsport does sell them see item 09035, the unit fits Sp15 and D18 transome fittings.
Windsport Technical support
chris prior
Thanks for that Brian. Will have to see if I get a pension increase this year??
Slightly more than I wanted to pay!!
chris prior wrote:Thanks for that Brian. Will have to see if I get a pension increase this year??
Look Chris - you could have had this one for £20.
I did post it on this website a couple of weeks back.
http://www.ebay.co.uk/itm/Dart-18-Catam ... 3375414502
PS Does this mean that you are coming to Brightlingsea :wink:
chris prior
Thanks Bob. I did see it when you posted but was not going 'up North at the time otherwise would have considered it.
If you hear of any others let me know
Chris
