Batten problems [Kevin N.Wales]
Posted: Tue Jun 04, 2002 6:03 pm
by Archive
Kevin N.Wales wrote:
Had a good blast today in a steady force 4-5, but I noticed that the second batten up the sail had snapped just as it leaves the plastic batten protector, on the luff of the sail. I carried on sailing for a bit, but once ashore I took the batten out of the pocket. It had de-laminated about an inch from the end. I removed the broken bits from the protector via a tear accross the pocket caused by the sharp end of the batten.
Question
1.Is the batten nackered, could I repair it with polyester resin and glassfibre tape?
2.Should I get the batten pocket repaired by a pro, or is sail repair tape worth trying till the end of the season?
Batten repair [Boib]
Posted: Tue Jun 04, 2002 6:21 pm
by Archive
Boib replied:
If the batten is just delaminated and has lost no length you can repair it with polyester resin. You need to apply the resin and then clamp the batten between two bits of wood until the resin has set. Once the resin has set (12hours or so) take off the clamps and wood and smooth the batten with glass paper especially the end. Then bind the batten with insulation tape, including round the end (I do this to all new battens it reduces them wearing through the sail).
The sail will need reparing in due course - you can do it youself if you are good with a needle and have an oddment of sail cloth.
Bob C
