Page 1 of 2
Trapezing [Andrew Hannah]
Posted: Mon Feb 06, 2006 8:07 pm
by Archive
Andrew Hannah wrote:
Following an earlier thread, some of us in the Thorpe Bay Icicle series are now venturing onto the wire. So far, we have enjoyed the experience. We have read Mike Cemm's article in the "tips" section, and have come to learn that we cannot sail as close to the wind as with the una-rig mode.
But we came undone when we tried to trapeze whilst sailing on a close fetch. Sadly, Mike's article only covered trapezing whilst sailing to windward. Can any member advise us of the correct sequence of actions?
For example, should we come up to close-hauled, then get on the wire, and finally bear away as we step towards the stern? Or should the trapeze loop be lowered, and hook-up from an after position?
I tried the latter and found myself skidding along the sides, to the shrouds. Grippy tape was no help. I had another go, and gave myself a ducking. So I gave up.
If any of our Sprinting (sorry Sport) fraternity can throw any light upon how to trapeze on a reach, it would be most helpful.
Andrew Hannah,
TBYC.
Sporting [Bob]
Posted: Wed Feb 08, 2006 1:03 pm
by Archive
Bob replied:
Hi Andrew,
I'm not great at this, so I hope one of the Gurnard guys (or George) will add their comments. I find that as you come off the wind towards a fine reach or a reach you have to move further towards the stern of the boat and the further aft you go the more you need to get your toes in the toe loops to stop you getting flung forward. Generally you should not be changing course just to get out on the wire. You should head in the direction you want to go and then get out on the wire. When changing direction when already on the wire you need to be able to reach the jib sheet while on the wire. It helps if you get into the habit of putting the jib sheet between your feet, while you are on the wire. Then you can bend your knees to grab it as you bear away.
Trapezing [Carl from Gurnard]
Posted: Wed Feb 08, 2006 8:35 pm
by Archive
Carl from Gurnard replied:
Andrew
Trapezing on a fetch or on a reach is tricky technique that not many Sporters master - I haven't.
As Bob has said the direction should be set before going out onto the wire and the traveller adjusted accordingly. I let more traveller off and then pull it in a bit when I am out and ?in control?.
What I would disagree with Bob over is the use of toe loops. As you have found, trapezing off the wind is a little precarious especially moving further off wind when is also becomes possible to pitchpole. The thought of doing that with my foot in a loop had made me remove them from my boat.
The technique for staying put on the side is to bend the rear leg and try to lock the front one. This position is demonstrated on the Gurnard SC Press Day photos on the Photo section on this web site ? look at the pictures of Chris Johnson and Matt Smith. Ideally Matt should lower his trapeze line but as you have found you don?t have many spare hands when you are in this position.
I find trapezing off the wind for more than about a minute is very uncomfortable. It brings on pain above one of my knees (probably the rear one) that I find very distracting and then unbearable.
The question that you have not asked but I will attempt to answer anyway is ?is it faster to trapeze when you are sailing off the wind?? The answer is of course - it depends. On short legs (of the course) I feel that it is best to stay in board. On longer legs (like we have at Gurnard) gains can be made if you are on the wire and can keep it in control.
In rough conditions I think that you have to decide if the added risk of going over is outweighed by the dryer ride.
Sporting [Graham]
Posted: Thu Feb 09, 2006 4:49 pm
by Archive
Graham replied:
Hi Andrew
When I first of all bought my sprint I sailed it a lot in Poole Harbour (short choppy steep waves), I found sporting the only way to get good speed in any decent wind.
When sitting down the boat sailed lower in the water thus catching the tops of the waves and slowing down, when sporting I feel that some of my weight was exerted on the side of the boat thus the boat ride would be higher clearing the waves.
I agree with Carl, I never used the loops in case of broken foot syndrome, however instead of removing the loops try wedging your front straight leg against the back side of the toe loop (not actually putting your foot through the loop).
Also I got some great grippy tape from Steve Sawford that works wonders, it is about 3mm thick and could be a better quality than that you are currently experiencing problems with.
All the best
Graham
Stewartby
Sporting [George]
Posted: Thu Feb 09, 2006 6:45 pm
by Archive
George replied:
Andrew,
First of all - don't give up!!! It's not easy to learn new tricks when you are past your teens and twenties, but it can be done - I started sailing 36 years after I learned to sail in Cadets at 12-14 years old. I first went out on the wire on my Dart 15 when I was in my early fifties. I just wish I'd had the benefit of this current website, with all those helpful tips which are additional to the limited help available from books and so forth. And when those tips include 2 or more ways of doing things, recognise that there is nearly always more than one solution (which may depend on helm size and athleticism), try them all, and do what best suits you. So here's my essay :
As I see it, the cause of the difficulty of trapezing on a beam(ish) or broader reach is due to the short length of the trapeze wire - the hounds on the Sprint 15 are very low in comparison with most trapeze cats (ie all of them!!). Thus, when you need to be aft to keep the bows up on the reach, the trapeze wire is at an appreciable angle which pulls your torso forward. You have to position and brace your torso and legs to counter this, some of which effort may be assisted by use of the toe-loops. On a reach close to a beat, you will be less far aft so this forward pull is less, and so less of a problem.
I've trapezed on a Dart 18 on a beam(ish) reach in a gusty blow on a distance race in which there was just one tack in c14 miles round the only mark of the course. The rear toe-loops were broken and I eventually rejected use of the restraining line and hook as it hindered my moving forward when the gusts eased. The forward pull was MUCH less than on a 15, and readily handled as advised by Carl - you straighten the front leg and bend the rear leg a bit so your upper body is angled a bit aft to counter the forward pull. But I did let out enough of the adjustment on the trapeze wire to enable me to trapeze almost as low as I would have been when beating.
But even when you let out the adjustment on the Sprint 15 trapeze wire, the forward drag remains heavy. You can counter it as described by Carl or Bob. I sometimes use the toe-loops, sometimes not. (I've removed only the forward toeloops - which I never use.) I favour using toe-loops when the wind is less gusty because it helps reduce the uncomfortable strains that Carl mentions, keeping feet out when it seems that the risk of pitchpoling is greater - eg gusty wind and choppy waves. On a "close-ish" beam reach where the risk is nose-diving rather than pitchpoling, I tend to use the toeloops in the hope that my weight will stay back and a direct recovery from the severe braking remains likely (if you can't keep braced you'll swing forward and capsize is inevitable).
The alternative to trapezing aft is hiking out, rear knee over and rear thigh behind the rear beam, hiking out at an aftwards angle. I find this uncomfortable for any length of time, and getting back in difficult if I have been hiking out on a long leg. Further, Carl is rather heavier than Bob or me (or you if my recollection of your build is right!) and so he can hike and keep the cat powered up in stronger winds when we would have to de-power (even furl the jib?) to avoid nose-diving or pitchpoling, and this at lower wind strengths than would apply if we were on the wire and further aft.
On a long downwind leg in strong winds, I have been known to prefer a crouched position behind the rear beam on the wire to hiking out - you need to be aft more than "out" on the broad reaches involved.
As regards what I would do on a short leg - if I expected to luff up onto the beat at the next mark I'd get out on the wire for the reach regardless. If I expected to tack, or to gybe, or to bear away onto a broad downwind reach and hike, I might choose to hike a short reach. (My shoulder problem has meant I have hiked more often than I would prefer in recent years.)
If I were rounding a mark onto a close reach in strong winds, assuming the trapeze wire length is adjusted as for beating, I'd steer the cat onto the beat, go out on the wire, bear away a little and move aft while letting out a little main sheet if necessary. At this point I'd check the jib and main sail telltales, maybe letting the jib out a little, and then the traveller out while re-tensioning the main, then lengthen the trapeze wire before repeating the manoeuvre until I was on the close reach I believed right for fetching the next mark. Note that (1) you are quickly fully powered up on the beat and (2) this will push you more to windward of the boats that do bear away to the fetching angle directly, which might well prove to be advangeous as you power past them to windward, or keep them behind you in your dirty wind. Next time round I might hope to be quicker in getting to the right combination of traveller position, jib tension, trapeze length adjustment and helm position. In lighter conditions I'd expect to get to the right position etc directly first time. When doing this I'd probably keep the loop of the jib sheet round my forward arm so it would be ready for trimming, dropping it between my feet only when satisfied that further adjustment would be unlikely until the next mark - in a really strong gusty wind on a broad reach I'd want to be ready to dump the jib as gusts depressed the leeward bow....
If the trapeze wire had been left "longish", I might choose to go out on the wire further aft. When you do this, you MUST have your front foot FORWARD of your body AND push hard on your front leg to get out, with the aft leg merely ensuring your body doesn't twist inboard aftwards. This is because you have to counter the forward pull on the trapeze wire AS YOU GO OUT (my reading of your Chat was that you didn't realise just how important it is to use the front foot when going out, especially when further aft, so you weren't braced for the forward drag as you went out, with the result you describe). You can then be quicker to play and set the traveller and then the jib sheet while bearing away onto the reach. But BEWARE of going out on a "long" trapeze wire just aft of the shroud - it's then that becoming unhooked just before or as you go out is likely, and probably why I prefer to go out on the wire, length set for the beat, reasonably close to the shrouds and then move aft and adjust the trapeze length.
I believe sporting is much better than unarig in a short chop (because the tide flows so much faster off Sheerness it's worse there than Thorpe Bay!), because you can drive the cat so much harder and faster, moving forward and aft on the wire to trim the boat as it goes through the wave patterns (difficult if hiking), with huge benefit - the chop seems to me to slow a Standard boat down relatively more than a Sport, unless you can manage to get into a rhythmic groove swaying your body forward and aft through the wave patterns from the ideal relatively fixed position for your legs.
I agree about Steve Sawford's grippy tape - I use the toe-loops a bit less now.
I'd be interested in what lighter helms have to say on this subject - Tom Gall, maybe?
Finally, Andrew, if you find progress along the learning curve slow, bear in mind that Carl is spot on when he says that few master this aspect of Sporting a Sprint 15.
PS If Bob meant another George, a much better sailor than me, his thoughts would be invaluable.
Sporting PS [George Stephen]
Posted: Thu Feb 09, 2006 10:52 pm
by Archive
George Stephen replied:
Andrew,
A couple of further tips for when you go out on the wire :
1 If you are sure where the traveller should set, set it before you go out on the beat because setting it when out on the wire by the shrouds can be awkward unless your traveller car is very well maintained. Also true for a close reach.....
2 NEVER grip the tiller extension - let it slide through your hand as you go out on the wire or you will bear away with all that that entails....
3 If the Mainsheet is not as tight as you expect to trim it on the wire you may grip this as you go out.
Sporting (From memory...) [George Carter]
Posted: Sat Feb 11, 2006 12:32 pm
by Archive
George Carter replied:
Hi Andrew. The answers so far offer very good, insightful advice. I will try to add to these.
In my opinion Trapezing on a reach is hard, much harder than trapezing upwind. There are real benefits to trapezing on the tighter reaches. The benefits get less and less as the reach broadens as it is not normally heeling you are fighting, but driving of the bows downwards. This is lucky in a way as the broader the reach, the trickier it is to trapeze.
I think this is for several reasons.
Firstly because you are so far from the trapeze attachment point to the mast you can't trapeze perpendicular to the boat with straight legs like you do upwind. There is too much force pulling you forwards. You have to be either angled back with your back leg bent, which is tiring; or if you are far back enough you can put your back foot in the rear footloop to balance the pull from the wire. This means that in general you are much less stable and use up more energy and concentration just being on the wire. (I have no problem with using the footloop and use it all the time I am at the back - particularly when I think I am close to pitchpoling, it has saved me so many times! As soon as one breaks, I replace it immediately.)
Secondly the boat is moving faster, much faster than upwind, which means that the steering has much more effect and you are more easily put off balance.
Thirdly, also any waves are likely to be side on which makes the boat pitch more. It is much more difficult to trapeze on a broad reach on the sea than on a lake. The waves are a real pain when windy on the sea and are normally the reason I come in off the wire on a broad reach sometimes.
Fourthly, sail adjustment is needed more often. If you get overpowered, you need to let the sheet or the traveller off. If you point up like you would do on a beat you lose a lot of ground and you often need to point a long way to lose the power, this is more difficult from the wire. The main and jib need constant attention to be set correctly.
Getting onto the wire
If you are rounding the windward mark onto a tight reach then it is often easier to stay on the wire. In this case the jib sheet must be accessible so you can let it out correctly for the reach. I have two toe loops on each side of my boat and loop the jib sheet around the forward one. If you do not have these toe loops you have to leave the sheet dangling over the edge. You will normally need to let the traveller off too to avoid being overpowered. You are better off easing the mainsheet too at first and gradually pull it in. If you start the reach overpowered you lose a lot of ground getting the boat set up and getting back on course.
If you have gybed onto a broader reach or are rounding the windward mark onto a broad reach it is normally better to get in, set the traveller and jibsheet up then get out on the trapeze again. You can point up to get out on the wire, this will lose you ground. I would advocate this maybe at first when you are experimenting and building confidence, but if you cannot get out onto the wire in the first place at the back of the boat on a broad reach, then you will probably be better off staying in and concentrating on keeping the sails trimmed. It is more difficult to get out onto the wire at the back of the boat as your hook will need to be further off the deck due to the arc of the wire and you will need to be leaning back from the very start to counter the forward pull of the wire. It is the same basic technique to get out onto the wire on a reach, but these factors do make it more difficult.
Here are a few general tips to gain confidence trapezing in general so you can progress to reaching:
Practice trapezing upwind with the height adjustment set very low. This needs a bit more skill as you may hit a wave once in a while and it does feel less secure for some reason. This gets you flatter on the wire and means you can move back to trapeze on a reach without ending up standing on the boat when you move aft. As a minimum the triangular part of the ring should be touching the deck. When the waves are not too big then the circular part of the ring should almost be toughing the deck. This does depend on how tight your harness is too, but mine is very loose so this should be achievable.
Build your skills on the trapeze by gradually bringing your feet closer together upwind. When sailing upwind, unless it is very bumpy you should be able to have your feet together all the time. Once you can do this confidently, you will find that you are more confident when on a reach
Get grippy tape. This made a huge difference to me when I put this on my boat 3 or 4 years ago. I felt much more secure on the wire when in waves. Also if you accidentally step on the Jibsheet you don't slide over straight away!
When sailing upwind practice adjusting the jib and main traveller from the wire. This is a skill you need when sailing on a reach.
When you first practice on a reach, do it with the jib furled. I think the jib adds a lot of complication and when you are first getting confidence wriring on a reach you are better off without it.
If you are in a race and you don't feel comfortable on the wire and you think you are not in full control then STOP and get back in. Lean out for all you are worth and don't worry about it. There comes a point when discresison is the better part of valour and it is just too risky. Everybody does this at some point, myself, Robin, Laurie, Carl. Particularly as the reach is broader and the waves are bigger! I am often surprised how little benefit I get when trapezing on a very broad reach in big waves with my heart in my mouth compared to the people around me who are not!
Philosophy
Finally have fun. I think the idea of sailing with the jib and trapeze it to have a little fun and be a bit more out of control :-) To get a little philosophical... Looking at sporting vs sprinting I think it is a different mindset. Sailing Una-rig tends to be more tactical as you should be almost always in total control and correctly trimmed, you can really focus on the tactics and fine tuning of the sails and boat trim. Sporting, is a percentage game. Nobody is in total control all the time when it is windy, nobody is perfectly trimmed all of the time, nobody sails the perfect course, nobody gets every tack/gybe right, nobody starts perfectly every time, nobody can see all of the marks (Gurnard), nobody trapezes on every reach and everybody capsizes once in a while.
If you're not having fun or are feeling frustrated, furl the jib or come off the wire. You will often lose less than you thought.
Good Luck!
P.S. The lake is frozen here......
Lot's of words [Anon]
Posted: Sat Feb 11, 2006 9:34 pm
by Archive
Anon replied:
I'm sure that Andrew wanted a yes/no answer.
Try answering this question
What do replies from respondents with the name George have in common?
Anon
PS a clue could be in the title
Anon [George]
Posted: Sun Feb 12, 2006 2:00 am
by Archive
George replied:
Miserable sod, won't bother next time!
Anon: You are wrong. [AndrewHannah]
Posted: Sun Feb 12, 2006 8:26 pm
by Archive
AndrewHannah replied:
Take no notice George. "Anon" is completely wrong. I certainly never wanted a yes/no answer.
Rest assured, I have been advising my friends to take a look at the excellent replies the two Georges, and others, have given. I know for a fact, that cat sailors from other classes look at the Sprint 15 website. None of the other classes have anything, approaching the level of activity of ours.
I have every intention of coming back to this thread, to thank and comment upon all those who have posted, bar one!
Andrew.
George's answer [Duncan Ford]
Posted: Mon Feb 13, 2006 9:51 am
by Archive
Duncan Ford replied:
George - Take no notice of Anon. Anyone who can't identify themselves in a reply doesn't deserve web space anyway.
Your answer, and the time and trouble taken to go into welcome detail, was very much appreciated. I am sure that appreciation extends widely in the Association, which is unique in sharing information and advice. Long may it continue, and many thanks!
Duncan Ford
Sporting [AndrewHannah]
Posted: Tue Feb 14, 2006 4:06 pm
by Archive
I thought I'd make a post before this thread disappeared from the bottom of the screen.
I am sure I speak for many, when I say how helpful contributers have been. I am also struck by the humility of our best sailors, when they say trapezing on a reach presents problems for them aswell. This reserve has long been a trait of the Sprint 15s that I like.
It would be difficult to reply on every comment made. Suffice to say, each contributer put a different slant on the subject, from which the rest of us could draw conclusions. A simple point raised by George S about the hounds being low, and the ramifications thereof, might have been obvious. But it needed pointing out, for the benefit of lesser folk like me.
And of course, the contribution by George Carter (from memory? eh? what?) was magnificent.
All the comments are worthy of being collated somehow, and added to the "tips" section.
Thanks again.
Andrew,
Thorpe Bay.
Trapezing/Sporting [Graham Collett]
Posted: Thu Feb 16, 2006 9:44 am
by Archive
Graham Collett replied:
I am currently considering changing boat to a boat which allows occasional two handed use with a teenage son.
However my main use will be single handed racing in the trapezing format as I prefer tapezing to hiking.Question is how active is the trapezing race circuit as many of the events appear to be for una rig boats.
Graham
Trapezing/Sporting [Bob]
Posted: Thu Feb 16, 2006 2:00 pm
by Archive
Bob replied:
Hi Graham,
All events except the standard National Championships are open to all formats and are worked out on a handicap basis. Just lately more standard format boats have been taking part but it is not always the same. Sporting is great for open waters / big lakes.
At a Club level some clubs have the majority of the sailors trapezing these include Instow, Gurnard, Carsington, etc. A number of Clubs have mixed formats sailing, these include Queen Mary, Grafham, Stewartby, Swanage, Thorpe Bay (recently), etc. The rest are mostly unarig/ standard format.
Our boat is fairly unique in that so flexible that Dad (or Mum) can race it competitively with our without junior - depending on how junior feels.
I hope that this helps - if you want to have a trial sail somewhere near to you please send me your location.
Sporting [Robin from Gurnard]
Posted: Fri Feb 17, 2006 1:33 pm
by Archive
Robin from Gurnard replied:
Hello Graham,
There are a large number of clubs that just go 'Sporting'. In MY opinion, the boat is much more fun to sail and race.
The sporting scene is very very active. It only gets beaten in the headlines because unirig came first. It has to be said that most people are 'go both ways'!! Ha Ha Especially George C, who wins both.
Shanklin are a unirig club (and hence have a very high average age), but even they have started to do Sport series each year.
Gurnard are a Sport club. You can sail any format you want, but first over the line wins.
Come to the Sport Nats at Instow in May. Always a good turnout. Great place to sail.
Happt Sporting
Robin
