I have a problem with 1 of my rudders. The contoured corner which holds the roller in place to keep the rudder raised has lost the lip at the external corner. This seems to cause the rudder to easily fall back down if the tiller or rudder moves at all while manoeuvering the boat out of the water. Is it possible to rebuild up this corner using some sort of cement/gelcoat/epoxy? If I could rebuild this corner back up, I should be able to re-fashion the contoured edge using a half-round file to match my other rudder. Unfortunately I don't know what substance to use to build back the missing corner or where to get it.
Any advice appreciated.
