Posted: Sat Apr 04, 2009 5:55 pm
Hi David,
You can try spraying the rollers with dry lubricant like Holts Prolube which often improves things - but keep it off the tramp and the hulls otherwise you will be sliding around. If that does not do the trick you need to replace the 4 rollers - you may not be able to see the flats but they are very hard to see.
Rail corrosion
Posted: Sat Apr 04, 2009 6:26 pm
Hi David,
Once you have sprayed the rollers (best to take them off and spray the roller spindles as well) and before your try moving it around try the following.
Check the wheel side surfaces as well to make sure they are the right way round on the spindle, one side normally has a shoulder near the centre that I always put that nearest the base of the spindle to minimise friction.
Also feel along under the flanges of the rail - the ones the wheels actually make contact with. The top is irrelevant - unless you have some 'dings' on the edges. As time goes by they start to build up some oxidising that feels rough - the rail should feel smooth.
If it is rough or your finger 'catches' in places then it is time to clean it up - but not take off what anodising is left.
I do that by scrubing it with hot water and a little washing up liquid. Then once dried rub along the whole length with the edge of a hard piece of plastic - I found one of the grand daughters' lego bricks was ideal , but don't tell them as they having been looking for that brick to finish something !
Posted: Mon Apr 06, 2009 2:11 pm
by Keith
hi David,
I had the same problem. I replaced the white wheels and the track ran much better. On examination the old wheels did not look that bad/worn but the new ones certainly ran much better, in light winds the traveller would run by itself to the end of the track when turing onto the run.
Keith 1840
Posted: Mon Apr 06, 2009 3:28 pm
by Martin Searle
doram wrote:Hi Keith
That's interesting. Was their much "slop" after you swapped them, and do they just pull off of does one need to drive out the pins?
David 1324
To remove the traveller car:
1) Unscrew one of the track end stops (at least on my boat)
2) Slide the car to the open end and carefully tilt the car up and slide out, the wheels should just fall off since there is nothing left holding them in.
To replace:
I found I had to do the first two wheels, slide it in a little bit and then do the next two wheels and then finally slide it home.
The rear beam housing can sometimes get in the way in this operation hence the tilt up bits.
traveller service
Posted: Mon Apr 06, 2009 9:20 pm
Hi David, I think it would eb a good idea to take the traveller off and give it a service.
You may need to losen the trampoline and pull it down the track a bit to allow the hull to spring out a bit and get the traveller off or better still the new wheels and traveller on!
While the traveller is off, check the u plate for cracking and the triangle plate the jamming cleat is attached to. The swivel joint between these two parts should have no slack, adjustment is done done via the screw and lock nut, you will get the hang of it , but the setting of the screw and lock nut can be testing!
On the traveller line rubbing thing, I suggest you first try a thinner traveller line, yours may be 9 or even 10mm , suggest 7mm of good quality traveller line.
Replacing your dead eye with a set of rollers is not quite as simple as the screw holes do not line up. Give me call if you want to talk it through.
Brian Catparts Windsport.
