Rudder drop
Posted: Sun Jun 21, 2009 6:28 pm
by Derek James
Hi ,
I have a problem with my rudders dropping down from the raised position during launching or recovery from the water . I have serviced the rudders and have a good action to raise or lower the rudders on the water . It seems that a good jolt of the boat when pulling it up or down the slipway causes the rudders to drop and chip the blades . Any advice on how to resolve problem would be much appreciated .
Derek.
Posted: Sun Jun 21, 2009 10:24 pm
Hi Derek
Yes this is a common problem. The best fix is to take a half round file and file a notch in the detent where the roller goes to lock the blade up. Just a mm or two is enough. Another slight improvement can be gained by tightening up the pivot bolt on the rear of the bracket on the tiller arm which clamps the rudder blade and adds friction. If your rudder has been correctly assembled there should be a thin plastic washer on each side between the bracket and the rudder blade. Many boats were assembled incorrectly with these washers on the outside of the bracket where it does no good at all. If this is the case take the bolt out and assemble it correctly.
Posted: Sun Jun 21, 2009 10:32 pm
These washers are not shown on the parts list on this web site. Go to Manuals/Parts List/P5 and see part D40271. There should be a thin plastic washer on each side of the rudder blade between this part and the rudder blade. These washers prevent wear on the rudder blade and provides friction when the clamp bolt is tightened. If you do not have these washers they can be made from thick polythene like that used on building sites as damp proof membranes.
Posted: Mon Jun 22, 2009 7:22 pm
by Derek James
Bob ,
thanks for feedback , I cannot find the part List p5 part D40271 that you refer to but think I can make up a washer based upon your description .
I am obviously nervous about taking a file to my rudder blade , any tips on shape to file ? Do I file below metal bracket D00090 on web site manual , should the rebate be mostly round and a larger OD to the wheels that drop into rebate ?
Derek.
Posted: Mon Jun 22, 2009 9:51 pm
Hi Derek
Yes ideally the notch needs to be a similar diameter to the roller, but anything from a half round file to a round file of more than 0.5inch diameter will do. File a little off at a time with the rudders on the boat so you can judge the effect.
The parts manual link is
http://www.sprint15.com/manuals/parts_list/section5.jpg
Posted: Mon Jun 29, 2009 5:27 pm
Hi Derek
Would it be useful to tie the tiller cross bar down, maybe using the mainsheet, once the rudders are up? If you can secure it the rudders shouldn't jump out of the notches.
