Water in hulls
Posted: Mon Aug 10, 2009 12:25 pm
by Jaycb
I am certain that there are no "below the waterline" leaks in my Dart's hulls yet over a season they both seem to take on some water (not a great deal, but it can be heard sloshing about). A fellow club member reckons it's because of an expansion breather hole in each hull - does anyone know if this is true, and if so, where is it located please?
Re: Water in hulls
Posted: Mon Aug 10, 2009 2:08 pm
by Martin Searle
Jaycb wrote:I am certain that there are no "below the waterline" leaks in my Dart's hulls yet over a season they both seem to take on some water (not a great deal, but it can be heard sloshing about). A fellow club member reckons it's because of an expansion breather hole in each hull - does anyone know if this is true, and if so, where is it located please?
Hi Jacyb,
Yep entirely normal to get water in the hulls, make sure you empty it out before and after each sail. Mine gets water through the hatches since the seal is not 100%. Also if you leave the hatch covers off when not in use then rain can get in.
I forget exactly where the breather hole is but I do know its drilled in one of the beam housings but in the underside of the upper part of the housing to minimise water ingress. Bad things happen if its blocked up apparently. I'm sure Brian, Steve or Bob can give you the low down here.
Posted: Mon Aug 10, 2009 3:06 pm
by Frank
If you have a full cover, remove all four hatch covers when your boat is stowed. This will dry the hulls out nicely.
Posted: Mon Aug 10, 2009 4:36 pm
by Jaycb
Thanks guys. I do have a full cover so will try Frank's suggestion.
Martin - yes, I guess if it gets blocked then the whole structure could split apart on a very hot day
Water in Hulls
Posted: Tue Aug 11, 2009 10:28 pm
by George Stephen
If you sail on the sea it is always best to sponge water out of the hulls after each outing. Otherwise salt will build up inside, mainly in the flotation foam. Hull weight will increase and the inside of the hulls will rarely ever dry out properly as the salt attracts moisture in the air.
Frank's advice is best applied after sponging out, not as an alternative to leaving the water inside to evaporate.
Hull breather tubes are in the rear beam housing, with the "external" end starting from the topmost part of the inside of the housing, in the middle. I don't know whether they run forward or back round the housing, and where they end inside the hull. Newer boats may be different....
It's much more likely that water comes in past/through rivets in the hull decking, past poorly sealed hatch fittings, or past the machine screws that hold the rudder pintles and gudgeons. Other possibilities include the chain plate screws....
