Hole in bottom section of mast
Posted: Tue Nov 03, 2009 9:07 pm
by RobBowen
This is more to pass on some info I've found out lately about my mast - It could all be drivel (as usual) but a couple of specialist mast people have said the same thing.
The hole / crack has been in the mast since I bought the boat, and there are smaller holes round the other side. They are where the waterproof plug is at the top. Both mast people said that it is "Electrolytic corrosion" caused by a reaction between the mast and another metal in the plug (probably steel of some sort). If this is the case, then it may not be an isolated issue on some older boats, so may be worth checking out.
The advice I was given (by 3 seperate specialists) was to rivet on an 18 inch "doubler" or sleeve over the affected area, which I made out of an old section of mast Steve Sawford gave me (thanks Steve!). The result can be seen below.
No oil painting, but hopefully it will prolong the life of my mast!
Rob 1348 Batcat (Bats sleep upside down)!
Posted: Wed Nov 04, 2009 4:10 pm
Yes I've got a bit of this too, Rob, and it is in the same place. I earlier found some rivets through such defects which looked like an attempt at repair by an earlier owner. Unfortunately I think that this has led to some further electrolytic corrosion. My current plan is to use chemical metal to glue a patch over such faults where they occur (I have two - one hole and one crack). As I am presently trialling chemical metal to prolong the life of my mast ball and mast heel casting I think that the stuff is up to the job, especially since the defects have not significantly worsened since I have had the boat (as far as I can tell anyway).
Posted: Wed Nov 04, 2009 7:33 pm
by RobBowen
Thanks Robert - I may have a go at that mast ball thing!
Posted: Wed Nov 04, 2009 7:34 pm
by RobBowen
And I'm going to keep posting until I'm not an able seaman anymore...
Posted: Wed Nov 04, 2009 7:35 pm
by RobBowen
Even if I've got nothing to say...!
Posted: Wed Nov 04, 2009 9:35 pm
by Robin Newbold
You're just trying to get your post count up!
Posted: Wed Nov 04, 2009 9:57 pm
by RobBowen
Shamelessly! - I'm done now though!
Mast Ball thing
Posted: Thu Nov 05, 2009 3:08 pm
If you have a spare, soft-ish plastic tow-ball cover then you can possibly use it to mould the chemical metal onto the mast ball and even inside the mast heel casting. Be sure to file down the metal surface a bit first so that the product can bond properly with the aluminium. If the cover is a spare it is good to cut a bit off so that it can easily rotate into place on the mast ball (make the side you want to build up a bit shorter than the other side. Spray some silicone into the adapted tow-ball cover, or add a thin layer of grease or Vaseline instead. Then you just have to add the chemical metal you have mixed to the part of the ball you want to build up before rotating the cover into place. Wait five or six minutes and it's done.
I tried this with a plastic padding product called "Super Steel" for the Nationals but that broke down, probably because I didn't lubricate the ball properly before raising the mast. So far so good with "Chemical Metal" and some grease to stop it interfering with the lining I've put on one side of the mast heel casting.
To do the heel casting, just use the outside of the tow ball cover as a mould and don't apply too much Chemical Metal. You only need to build up the casting where the ball would be in contact with it. Even a new ball and casting aren't anywhere near a tight fit and generally would have a few mm gap between the two.
