Rig tension - am I doing something wrong?
Posted: Mon Aug 02, 2010 12:59 pm
by Jaycb
Hi all,
The last few times i've sailed my Dart have been very windy, probably at the limit of my ability, and as a consequence the sea has been pretty rough. I've noticed that when I'm drifting with little power in the sail (e.g. waiting for the start), the swell causes the whole rig to snatch and jerk horribly, sending massive shudders through the boat. It just doesn't feel right. However, I've set up the shrouds and forestay exactly as recommended on here, with a few inches of play between the mast's forward-most point of travel (when it's pulling against both shrouds) and it's rear-most point of travel, when it's pulling against the forestay.
I just re-read the "raising the mast single-handed" article and it reads as if there is no play at all - says something along the lines of having the boat leaned forward and then with the mast hanging from the shrouds the forestay string being tightened up so that the mast can swivel but no looser.
I guess what it comes down to is how much should the mast be allowed to sway backwards and forwards?
I'll ask Charles to take a look if I see him during the week but in case I don't get a chance can anyone else advise please?
Thanks.
Posted: Mon Aug 02, 2010 3:31 pm
Hi Jes,
It sounds like you may have a bit too much slack. My article says:
"Tighten the purchase until the mast just swivels freely without excessive slack (most of us grease the top of the ball joint so the mast turns freely and the rigging can be tighter)".
In fact the mast needs to be able to just turn 90 degrees in both directions. When you do this you end up with a bit of slack and the mast can rock a little. In stronger wind you can tighten the rigging a little more but the mast will still rock if you just sit in the swell. Sheeting in a little and keeping the wind on one side of the sail while pinching will help.
Rig Tension
Posted: Mon Aug 02, 2010 11:09 pm
by George Stephen
You want the rig tension to be right for when you are racing, not for when you are sitting around in a swell.....
My rig does exactly what yours does in those conditions. If I'm going to be hove-to for a length of time I let off some of the downhaul tension, which seems to help a bit. And this is with the rig tensioned in line with Bob's article - ie allowing around a 90 degree rotation each way.
It does help to tighten the rig tension (limiting mast rotation to significantly less than 90 degrees each way) if you are sailing in light winds in a lot of wave action - eg after a period of strong wind conditions has blown over. But only for sailing standard una-rig mode - I wouldn't do this if I were sailing with the jib (2 up or Sport mode).
In the days when Beaver sailors were very successful Standard Una-rig sailors, they always seemed to sail with tighter rigs than Bob's guidance, regardless of conditions. There's no unique right answer.....
Do chat with Charles.
Posted: Tue Aug 03, 2010 7:31 am
by Jaycb
Thanks for the advice guys.
I need to drop the mast tomorrow to fit a new jib halyard so will take the opportunity to have a good look at the setup.
Cheers.
