Avatar Images
Posted: Wed Jan 05, 2011 4:36 pm
by Martin Searle
Folks,
To add in an avatar image you first need to get a file which meets the following requirements:
1) upto 120x120 pixels in size
2) no larger than 10kb
In the top left corner of the forum page you will see User Control Panel, click this.
Click the Profile tab
Click Edit Avatar
To upload your avatar file from your machine click browse and select it then click the submit button, if it doesn't meet the criteria you are told what is wrong and the file is not uploaded. If everything is OK then the file is uploaded and appears in the box on the screen thus its active.
You can upload as many avatars as you want and can choose between pictures by clicking the Display Gallery button.
Martin Searle
Re: Avatar Images
Posted: Wed Jan 05, 2011 11:32 pm
Well done Martin - Happy new year.
I was tempted to use my Land Rover forum avatar as it goes faster than my 15 but the process of uploading was the same as for that site.
Re: Avatar Images
Posted: Fri Jan 07, 2011 6:47 pm
Great idea Martin! Can you recommend software to shrink a file size as far as 10k and 120x120? Photoshop would do it but I don't have a W7 version and it means walking upstairs. Picasa doesn't go small enough and Shrink Pic only gets me down to 46k.
Re: Avatar Images
Posted: Fri Jan 07, 2011 7:01 pm
Hi Robert,
I use ACDSee9 which has a 'Resize' function in the tools sub menu to define the pixels (it keeps the aspect ratio).
This got me to 14kB. Then when I used 'save as' there is an options button in the 'save as' menu that lets you choose the compression factor. The factor is at 85% as standard so I set it to 20% and this reduced the file size to 7kb.
I have several other packages that allow similar 'resize' and compression factors in slightly different ways and I think most do. Resize is not the same as crop - it changes the pixel resolution but keeps the whole photo
My original photo was 750kb with my boat as one in a fleet, I cropped that to my boat and then resized and compressed.
Hope this may be of help.
Re: Avatar Images
Posted: Mon Jan 10, 2011 8:36 pm
Thanks Steve, that's pretty clear and I might well get ACDSee 9 but my slightly northern "Owmuch?" tendency has got my grey cell working (a bit). If I go upstairs and just
turn on the PC then I can use "remote desktop connection" to acquire and reduce the image remotely, then post it here from my laptop.
Wonder how long it will take me to get round to it?
Re: Avatar Images
Posted: Mon Jan 10, 2011 9:14 pm
Actually, I had help with this. (Thanks, M)
Re: Avatar Images
Posted: Tue Jan 25, 2011 9:35 pm
by George Love
Just having a go at this to see if it works. Having problems reducing the file size
Re: Avatar Images
Posted: Thu Jan 27, 2011 11:08 am
Hey guys
To create an Avatar or resize an image use this program
http://www.shrinkpictures.com/create-avatar/
Easy
Re: Avatar Images
Posted: Fri Jan 28, 2011 8:29 pm
"Simples!"
Re: Avatar Images
Posted: Fri Jan 28, 2011 8:56 pm
by George Love
Thanks, Bob. Hopefully it's worked
And so it has!
