Jib Set-up
Jib Set-up
Set the jib up on 2026 today, is there any dimentions for the cleat position along the tramp track.
I have arrived at a position using the diagram in Brians "Catamaran Book",the position I arrived at was- from the inside of the rear beam to the centre hole of the mounting plate was 740mm, seemed quite a long way back, but that was where it worked to be.
I will give things a try on Wednesday evening, but in the mean time any advice would be appreciated,
Thanks in advance
Simon
Re: Jib Set-up
Mine is set right by the trapeze bungee. If I knew what I was doing I would move it for different wind conditions.
Re: Jib Set-up
Thanks for that Liam,
I will move mine as in the current position I could possibly spent a lot of time sitting on /over them. Will use your position as a starting point and adjust them to see what works best. I think the both the tell tales should be flying when its right.
Kevin Dutch
Re: Jib Set-up
Post by Kevin Dutch »
I have mine near the trapeze elastic too
1938 Flying Dutchman
@sprint151938
Gordon Deuce
Re: Jib Set-up
Post by Gordon Deuce »
Simon,
If in doubt see the instructions. The manual states 525mm from the end of the track. Hope that helps to start with.
Re: Jib Set-up
Hi Guys
Thanks for the info, missed the 525mm in the instructions.
