Comments on this site are not necessarily the opinion of the Dart 15 committee.
Comments are not moderated and people's screen names may not be accurate.
We recently bought dart 15 1270, which my 13 yr old daughter sails. We have hit a problem in that as soon as the boat capsizes it immediately turtles. Another 15 at the club of similar age also does this, but the boat that Emma was borrowing before we bought hers will sit quite happily on its side. Whilst Emma can right the boat it is a pain.
Has anyone any ideas why the boat should turtle so quickly, we are suspicious of the two part mast? Is this a common problem?
Hi Jane
From what you say, it sounds like the top section is not sealed, so when the boat turns turtle, water leaks in to the top section, thus making it heavier and therefore more difficult to right. Also, if it appears to turn turtle straight away, it would suggest there is already water trapped inside, thus assisting a full inversion.
The favoured solution would be to put some silicone sealant round the joining sleeve where it enters the top section.
This is not a common problem, but the boat is quite an old one which could now be showing signs of fatigue.
A more expensive solution would be to swap it for a 1-piece mast - occasionally some people swap for a variety of reasons, depending on how often you trail the boat.
Also, the 1-piece mast is slightly lighter which could be a reason to change.
Finally, (the least expensive option)- quick reactions often help to avoid full capsize, so in this event, try to drop down the outside of the hull rather than drop onto the sail side and have to swim round the back of the boat(speed is of the essence). You can then go straight onto the inside of the leeward hull and grab the righting line from the front beam. Another aid often used is to employ a longer traveller rope which initially ties round the mast ball on the front beam, and runs under the trampoline to the centre eye on the back beam where it normally starts from. Then, providing the traveller is un-cleated, you can pull on this rope or even put it behind your back so you can lean further out to assist with the righting moment.
Hope the above helps.
Paul Smith 1961 Beaver S.C.
