Strengthening rudder-mounting area.
I'm beginning to think that the rudder-mounting area at the rear of Dart hulls is a weak spot. Yesterday at Seaford a few boats complained that they'd run over the ropes to some lobster pots. Normally fishermen are meant to hang chain on the first bit of rope below the buoys but some egit didn't and the result was around 20 metres of floating rope just waiting to snag daggerboards and rudders.
One of the Dart 18s suffered a rudder failure as a result and had to come in. I ran over the ropes three times and the rudders kicked up perfectly with no apparent damage.
However, when I was packing up later on, I had a close look and the gel-coat at the very bottom of the bottom gudgeon pin had a fine hairline crack. There didn't seem to be any more water in the hull than normal so I believe it's just a stress crack caused by flexing of the rear panel when the rudder hit the ropes.
What I'm wondering is if others have grown tired of this sort of thing and if anyone has strengthened this area to avoid flexing and thus cracks in the gelcoat? I'm thinking of just smearing a load of glass-filled filler around the inside edges and then painting on loads more gelcoat, inside and out.
Any other suggestions?
On a happier note, it was another fantastic day's sailing (I reckon that in total I was on the water for nearly four hours) with a real humdinger of a sea-breeze kicking up late morning. Although with the handicap I didn't win anything I did beat a Dart 18 in one race and best of all, crossed the finish line first in the last race, despite two down-wind cock-ups.
:D :D :D
Pintle area
I looked at this when I was doing my relaignment of the hulls and rudders (see Keith Bartlett's thread). Unfotunately the bottom two bolts are very very close to the underside of the hull and there isn't much room for work at the join of the transom and the hull. I did however put some fibreglass mat inside across the top two holes and then used larger stainless steel penny washers on those two.
Not sure how much it has helped but no problems
Worth a chat with Steve Sawford.
He re-built my stb transom when it was all but removed in an unfortunate collision in the last race of the Nationals.
If the transom itself had needed strengthening then he could have done it quite easily as it was hanging on by a thread!!
