Sporty Corner
Sporty Corner
Would anyone like to comment about Sport Mode? Is it my imagination or is this more of a rare breed than it was? My view is that Una Rig is a happy branch and works well for TT's and the Nationals. The European Trophy was a big success, too. This is all good. But are some people missing out on sailing in Sport Mode because we don't do much of it in general?
Instow this year was great and it would have been even better with more travellers taking part. Hopefully Yaverland will create lots of entries next year. Does anyone have any ideas about how we could make this more likely?
Re: Sporty Corner
Hi Robert
Have all the sporty bits, just none of the skill, end up a mess of rope dangling over the side, tiller extension hooked into the back of my bouyancy aid, feet sliding down the hull, boat head to wind....Could do with some confidence building coaching plus advice on a good harness, mines a bit tight where it shouldn't be.
Re: Sporty Corner
1. DANGLY ROPE -Try not to let too much dangle over the side as it's not very good round the rudders :? . Solution: chuck it on the tramp but leave a loop (can be touching the water) dangling over your front leg so it is easy to control. Don't worry too much about the jib sheet, just try and keep it towards the front of the tramp, away from the main if you can. If you are really good, leave some dangling over the windward side so you can reach it to adjust if necessary. If not just carry on regardless :D .
2. TILLER EXTENSION - Occupational hazard, but not unsolvable. Best to practice this one :lol: .
3. SLIDEY FEET - Get some "grippy tape" from Steve or Brian. When you stick it on leave 1/4 inch gap below the top of the side of the hull otherwise you might begin to peel it off with your bum when sitting out.
4. BOAT HEAD TO WIND - Grab trapeze handle with forward hand, put forward foot on the gunwhale, rest the tiller extension and other hand on the rear beam housing and push yourself out with this hand. As you get out bear away a bit (don't leave the tiller on the beam housing or you won't be able to steer - take it with you :roll:). I leave the main cleated and bear away a bit; some prefer to pull the sheet in as they go out. I'm not good enough for the latter but you might prefer it.
5. HARNESS - I didn't know what to get but settled for a made to measure nappy harness from Pinnell and Bax. I love it. No real experience of anything else but I'm wary of tight straps in delicate areas. No fiddling with adjustments, just the overall tightness of the loop I pull over my head.
6. CONFIDENCE - What we need is a location where we could meet up, perhaps where other cats are racing, and have a small event-come-training session. Does anyone have any ideas on this? Bala might be OK for Kevin but there's Rutland, Carsington and Draycote. Maybe a few people might like to go on holiday to Llandudno?
Useful suggestions appreciated.
Re: Sporty Corner
I feel that we have done our bit for the promotion of more string on the boat by allowing Erling to win the Sport Mode series at Shanklin.
It may encourage the other elderly sailors to join in.
Robert wrote:Would anyone like to comment about Sport Mode? Is it my imagination or is this more of a rare breed than it was? My view is that Una Rig is a happy branch and works well for TT's and the Nationals. The European Trophy was a big success, too. This is all good. But are some people missing out on sailing in Sport Mode because we don't do much of it in general?
Re: Sporty Corner
PS
To begin with, just trapeze upwind. Reaching on the wire requires a bit more confidence and can lead to tiller up the life jacket, bouncing along the gunwhale, dangling from the hook and suchlike. It's great but do the upwind experience first.
Re: Sporty Corner
Thanks Liam, that's quite useful but not quite what I was hoping for . . .
But if Erling can do it, anyone can.
Re: Sporty Corner
Both Paul & Kevin decided to do all the TT events this summer in sport but no one has joined them so I expect they will go back to main only next year.
Re: Sporty Corner
Hi,
Earlier this year I posted http://www.sprint15.com/forum/viewtopic ... 469#p19809, which pointed out the additional rigging and de-rigging hassle of sailing Sport Mode at a Traveller Event, but as I also have clearly enjoyed sailing Sport Mode (as seen from my past Travellers record) I also challenged Sprinters to sail Sport Mode in this year's summer traveller events; Kevin Dutch has told me that he and Paul Grattage have been sailing Sport Mode this year to take up my challenge.
If Paul sails well in Sport Mode at Grafham he may become the first Sportster to win the Overall Traveller Series this Millenium.... I think that finishing ahead of both Paul Craft and Stuart Snell and in no lower than 7th place would mean he would win the Series on countback from Kevin Dutch and then Paul and Stuart if Kevin won at Grafham. I think that such a win by Paul might be just what is needed to encourage more Travellers to sail Sport Mode.
For Liam, I would point out that when I last won the Sport Mug (2011) I was older than Erling is now, so Erling can't possibly be old enough yet to be classified as elderly......
For Kevin Parvin and others thinking of taking up Sport Mode, I recommend getting a little trapezing practice crewing on a 2 man boat (so that getting out and in on the wire becomes something you are comfortable with in a more controlled and less demanding environment).
Then, when there's a decent breeze sail your Sprint 15 without a jib (either not rigged or furled) and trapeze your Sprint15 with less string around! Get comfortable with moving forwards and backwards to trim the boat fore and aft, and moving aft after you bear away from a beat to a reach and vice versa - you'll also need to let out the trapeze adjuster as you move aft and shorten it as you go forward, and you need to get comfortable with this. It helps to have the grippy tape that Robert recommends (I got mine from Steve Sawford).
As you go out on the wire, I have 3 key recommendations :
1 ALWAYS push out harder with the front leg - you can even push out with just the front leg and then put the aft leg on the side of the boat when you're well out - just to prevent you being flipped back into the boat sideways!
2 NEVER grip the tiller extension - let it slide through your hand so you don't bear away, but retain enough friction to prevent luffing.
3 Before you go out on the wire, set the Traveller roughly where you think it needs to be, with any depowering of the rig managed by the twist in the main from a less than fully pulled-in mainsheet. Hold the mainsheet in a hand as you go out, initially letting it slide through the hand but gripping it firmly as you are getting towards "right out on the wire" - this will power up the mainsail and balance the boat better against your weight - this ties in with the usual Sprint15 advice on tacking - let out a foot or so of main as you tack, get the boat moving on the new tack and then harden up the mainsheet and luff marginally at speed on to the new beat. You can then adjust the Traveller if necessary - it should be easy to flip the traveller sheet out of its cleat and adjust the traveller car to where you want it; do the trickier bit of cleating it by catching the traveller sheet in front of one of your feet, toes angled forward so that the sheet is so low across the trampoline that it has no alternative but to cleat.
Sail quite a lot unarig on the wire so that you can do all this "comfortably" before adding the complications of trapezing and handling the jib as well.
Meanwhile, on calmer days when you wouldn't need to go out on the wire you should sail with the main and jib (and that long tiller extension!), to develop a routine for handling both the jib and main. My tip is to get the jib roughly right as quick as you can but a bit loose, get the main right and then the jib. Try to develop a routine which you can also take out onto the wire.
Then with the confidence that will come from the competence you'll have already developed you use the full Sport rig in a decent breeze. As you go out on the wire, take the jib sheet out with you (as well as the mainsheet which you're going to pull in a bit as you go out! - see above). Get the main set first, then the jib and away you go - it really is so much more exhilarating than sailing Unarig Standard Mode. To adjust the jib, the blocks must be set so that you can easily uncleat the jib sheet, and cleat the sheet by pulling the sheet in around a foot with the toes sticking up over the deck and angled aft.
You'll still have a lot to learn, absorb, hone your skills, develop more skills - especially sailing off-wind and more so in strong wind conditions. Yes, you'll make mistakes, have capsizes (including pitchpoles and cartwheels); if you persist, the mistakes happen less frequently - but there will still be those moments when keeping it up will be in doubt.
For the sceptics who have noticed I haven't sailed Sport Mode much recently, the wear and tear of my advancing years exact a toll that limits my physical activity. Will I be able to sail any 2014 Traveller Event, in any Sprint 15 Format? If I'm lucky!
Re: Sporty Corner
Hi George
I've done quite a bit of sport mode in the past, when sailing long distance races at sea, with plenty of breeze, works best for me. At Llandudno with a mixed fleet, 50 minute races and a difficult handicap I can't make sport mode work. I would like some practice though, nothing to fancy, just meeting up at a venue (Robert you mentioned Bala, sounds good to me) for a blast about with a couple of sport mode experts.
I havn't sailed the cat much this year, a new slip way is near completion at Llandudno North shore, right next to the club, something members have been waiting for since the club re-launched in the 1960's. Could be a venue for a future Welsh Championship??
Kevin 1615.
Re: Sporty Corner
George, thanks for your erudite and helpful advice. I must try some of that stuff. Next step: adjusting the trapeze whilst out on the wire and moving back on the reach! Even without such a skill I've enjoyed some fantastic sailing, flying out on the wire and, especially, going upwind with far less effort than when I have to hike out with Una rig. With practice, getting out on the wire becomes quick and second nature. This means you can trapeze for even short tacks.
Kevin, I look forward to getting together for some Sport Mode practice. It would be good if some others were there. I think the Catapults are coming to the end of their season, but next year might provide an opportunity. Bala could be a good call. Anyone else interested?
I can be contacted by email using the link on this page just to the left of this sentence (little envelope picture).
Re: Sporty Corner
NOR and SI's for the Draycote Dash this weekend:
http://draycotewater.co.uk/wp-content/u ... 153355.pdf
http://www.draycotewater.co.uk/results/ ... %20SIs.pdf
Online entry at:
http://enter.sailracer.org/events/enter ... tid=195890
Windguru looks favourable and Sport Mode handicap is 883.
Anyone going?
Re: Sporty Corner
I don't think the wind did you any favours............ :(
Well done for giving it a try.
Re: Sporty Corner
It was good in the gusts. There just wasn't enough gustiness :( .
Re: Sporty Corner
Robert wrote:NOR and SI's for the Draycote Dash this weekend:
Online entry at:
Anyone going?
The Grafham Grand Prix was put off until 22 February. This remains a winter open that is open to all catamarans. It could get better winds for those that want to try their hand at Sport mode. :wink:
Re: Sporty Corner
Looks like is going to be windy. Excellent for the Sprint 15s :D
