I probably know the answer to this query but thought I would share it. When the mast is dropped and lies across the back of the boat it has become increasingly difficult to remove the pin at the base (a second person has to lift the mast a foot or so off the track to make pin removal easy). I replaced the ball casting a couple of years ago and though the steel plate at the top of this casting remains good there's been quite a bit of wear at the back of the ball casting.
Looking at the heel casting today it is quite badly worn on one side, probably due to the prevailing wind direction. So my questions are:
Do I need to replace the heel casting (original 1991 fitting)? (probably yes).
Could a badly worn heel plate be responsible for difficult removal of the mast pin?
Can I get away with the ball casting for another couple of years, I've been told in the past that as long as the steel top is not worn it should be ok?
I've always replaced the plate in the heel casting regularly.
Kevin 1615
