I've been reading the "Tips from Phipps" article "Keeping your hulls on-line"
It looks like we might need to do some adjustments but I'm a bit confused.
With no bridle fitted and obviously the mast down our boat is about 10mm wider at the stern. Yet both hulls are touching the thrust pads on the inside of the read beam (and therefore can't move closer together). I assume that putting the mast up will only make the difference larger as tension in the bridle pulls the bows together a bit.
Brian doesn't seem to say what is an acceptable difference. Is a 10mm difference unusual?
At the same time the rear beam clip looks about right on the starboard hull but on the port hull the whole beam sticks out a little and the clip is about 15mm away from the hull (and now we know how to adjust the clip but not what can/should be done about the beam).
I guess I should re-measure with the mast up and tensioned.
Just interested to know what others have found.
Dave
