Dave, Strictly speaking it is out of class but is so trivial that I cannot imagine anyone protesting.dave42w wrote:Our #4 batten got broken (not quite into 2 pieces) sometime on our summer holiday.
I had a spare and have cut it to length and fitted it.
The original had foam stuck to it but clearly not where it hit the shroud and snapped. Rather than buy sticky foam from Windsport, at least for the moment, I've slipped an old bike inner tube over the batten and held it on with insulation tape.
Am I legal? Because this is a very simple and cheap solution if so.
Dave
That is true in strong winds but it limits the sail setting range in light winds.........Liam wrote:Have you got a knot in your mainsheet? Putting a knot in the rope so it can't go any further out than it needs to should help reduce breakages.
Bob Carter wrote:That is true in strong winds but it limits the sail setting range in light winds.........Liam wrote:Have you got a knot in your mainsheet? Putting a knot in the rope so it can't go any further out than it needs to should help reduce breakages.
Liam wrote:Only if you tie it in the wrong place.![]()
